A question about installing the applied racing smog block off
I have the applied racing smog block off kit for my 09 crf450x that i want to install. I didnt really understand the instructions that came with it so i went searching for a how to on the internet and found this:
http://crfsonly.com/reviews/ar-450x-smog/applied-racing-crf450x-smog-review.php
I have two questions:
1.) Which hose do you plug up by the airbox? The larger diameter one or the smaller diameter one?
2.) Where is the vacum hose and brass fitting located on the bike? could explain or post a picture showing more of the bike with this part highlighted? Its hard to know where it is by the pictures shown as you cant see any of the bike to go by.
thanks for the help.
The larger one that's above the smaller one.
Follow the small hose from the smog pump, itself.
It leads right to this fitting.
It is on the right hand side, immediately in front of the carburetor.
alright so i went out, i know where the vacumm hise is now. and i removed the hose up on the air box, but how do i get the piece that the hose went onto and into the air box? i tried pulling on it with plyers fairly hard and it wouldnt come out, i stopped because i was afraid if i pulled to hard i would fool something up. I also squezed in on the little clamp so it wasnt tight
http://s1050.photobucket.com/albums/s405/customsunday/?action=view&current=dirtbikehosething.jpg
heres a picture of it
Edited by ttr230rider6
That fitting looks the same inside the boot as you see in the exposed portion. Just grab it with pliers and pull hard while employing a twisting motion. It'll pop right out.
Thanks a million for all the help guys, i finally got it installed. The only trouble i had was when i was trying to screw the little brass bolt in, i drop it and it went under the starting motor and it took me like 20 minutes to get it. I had to put duct tape on the end of a pencil to get it since a magnet wouldnt work as it is brass. But it looks great, an nice clean look as apposed to the bulking stock shit lol. thanks again
