2005 RM250 Flat Bottom End
My bike feels abit hesitant coming out of slow corners ,theres a bit of a splutter then its not clean or crisp sounding , i've had the carb apart , cleaned it thougherly its got stock jetting , any suggestions ??
Most of those kind of problems seems to end up being the carb,, or, a small air intake leak,,,it's the carb 80 percent of the time,, make sure all the adjustments are excatly the same as before the problem began,,,,,pay close attention to the slow jet, and the needle setting......good luck, Bubba......Dr.D..
Thanks for the reply ..just seen the clip on the air box to the carb was loose would that cause it ?
It shouldn't. The air leak should be between the carb and motor. Check crank seals also.
