2009 200xc-w clutch fluid
I just bought a 2009 200xc-w today and have a clutch fluid question. The guy i bought it off of said he broke the clutch line and when he replaced it he used mineral oil. I want to replace the fluid but what should i use? What is oem spec? This is my first KTM and i want to do it right. Also any advise for a new KTM owner? I always wanted a KTM and finally had the $ to buy one! All we need now is spring to come here in western Pa! Thanks
Pull the cover on the the bars and use ATF fluid and bleed the line just like you would a brake line. Do so until you have fresh ATF fluid coming out the bleeder so you have no old fluid left in the line. Just did this on my 09 200 the other day and have improved clutch feel.
