05-07 OEM service manual
Can someone please PM me with a 05-07 CR250 OEM service manual?
I loaned my manual to the local race shop last week as they work on my bottom end and I need some info this weekend
Thanks
Edited by AXAxiom
Only have it in hard copy but if you tell me what you looking for and I can see if I can help.
Thanks ryanmac,
I just need info on the cylinder hardware installation, I'll use item numbers so you can refer to the parts breakdown
http://www.cyclecent...=2005&fveh=3276
Head stud torque and do I use thread lock? Item 9
Exhaust flange Torque? Items 8,18
http://www.cyclecentralpowersports.com/fiche_section_detail.asp?section=138929&category=MOTORCYCLES&make=HONDA&year=2005&fveh=3276
PV nut torque? Item 12
PV seal retainer torque? Item 13
PV Cable holder torque? Item 14
Thanks again, I really appreciate it!
Edited by AXAxiom
Cyl. stud 9 lbs.
Exh. fl. bolts 6.6 lbs.
the rest 7 lbs
I just put a complete with cylinder top end and only torqued the head bolts. (20#)
I used a very light grease coating on my studs to make sure there was no drag getting them to seat all the way.
Cyl. stud 9 lbs.
the rest 7 lbs
Thanks for your help
