08 shock fitting
im buying a new shock and i am wondering if the 06-07 crf250 shocks are the same as the 08. also is the shock on the crf250x set up the same as far as spring weight and valving as the 250r?
The shock from the 08 will bolt right up. The X shock will fit, but I couldn't tell you if it has the same spring or if it's valved the same. The 08 is just an upgraded shock from the previous years. Usually the valving is a little different.
