Suspension Shims
This is my first time revavling I get how everything works, but i was wondering do you think this shim stackwould be good for me.
Bike:2008 crf 250 r
Ability: upper c class
Spring Rate:shock 4.8kg Forks .42kg
Type: hard Packed
Weight:145
What Im Looking For:plush feeling, pop feeling for seat bounceing ,no wandering of the rear end, push into the turns
Forks:
BASE VALVE
15-31 x .10
12-30 x .10
3-29 x .10
28 x .01
27 x .10
26 x .10
25 x .10
12 x .10
13 x .10
14 x .10
15 x .10
16 x .30
REBOUND
2-20 x .10
19 x .10
18 x .10
17 x .10
15 x .10
11 x .20
MIDVALVE
1-20 x .10
19 x .10
Spacer
9 x .20
3-9 x 0.3
Shock
COMPRESSION
4-44 x .20
7-44 x .15
38 x .15
30 x .15
2-44 x .20
40 x .25
36 x .25
34 x .25
27 x .30
26 x .30
25 x .30
24 x .30
23 x .30
22 x .30
21 x .30
20 x .30
19 x .30
18 x .30
REBOUND
1-40 x .20
27 x .10
26 x .30
25 x .30
24 x .30
23 x .30
30 x .30
29 x .30
28 x .30
27 x .30
26 x .30
Note: the Bottom is the beginning of the stroke
Thank You
The fork rebound and shock compression look normal, but the others are just weird, where did these stacks come from? Are you replacing the midvalve spring? This is the main problem on the forks, the valving itself isn't that bad
your stack look crazy!!the crf 2008 need a replace on mid valve spring ,stiffer shock rebound and a little soft base valve
thats a good starting point
so the forks are ok for what i looking for but what stack number would u suggest for the rear what you mean by change the mid vavle spring and what about dlc coating i head of guys getting it done for like 90 dollar any clue
