Heads up XRL Dirt/SM Tons of Mods: FS
Just posted in classifieds.
It has a few mods :bonk:
à Stage 1 hot cam (great for high desert speeds) ($130)
à Brand New Stock Cam in box (great for hair scrambles) ($140)
à NX650 Second Gear (decreases the large gap between 1st and 2nd and makes 2nd a wheelie gear) ($30 + cost of rebuilding the transmission)
à Xr600 10.5:1 piston (why XR600, because it has the ideal compression, higher than stock but runs great on regular gas) ($180)
à Valve ground and lapped by XRs Only ($100)
à New Exhaust Valves ($100)
à New Cam Chain ($80)
à FCR40mm Pumper Carb (makes this bike rip!) ($250)
à Noss Carb Adapter ($65)
à CRF450R Forks/Triple Tree ($300)
à Custom built Emig Racing Steering Stem for CRF front end conversion ($115)
à 17” Warp 9 Supermoto Wheels (because they are fun as hell) ($950)
à Distanzia Tires (Like new) ($300)
à Dirt Wheels as well (New front Desert IT) ($95)
à FMF Power Bomb header ($250)
à FMF Powercore IV ($270)
à Acerbis 5.8 Gallon Tank ($215)
à Guts Racing Seat (Sooo much more comfy) ($90)
à Stock Tank
à Cyclerack Luggage Rack (you could carry a couch on this thing. Super Solid) ($160)
à Trailtech X2 Halogen 70W Motorcycle Headlights ($100)
à Heated grips ($40)
à SEA wire to battery for charging, plugging in GPS, Heated clothing …
à CRF450R rear fender with LED tail light ($100)
à Barkbusters ($60)
à Uni Air Filter
à IMS Foot Pegs ($80)
à Eastern Beaver 3 circuit fuse panel. 2 switched (one for heated grips, second is waiting for next accessory), 1 not switched used for SEA so I can hook up the battery tender ($45)!q
à 13, 14 and 15 tooth counter sprockets
à 42 and 48 tooth
à DID Chain ($180)
à Applied Racing Clutch Lever ($30)
à Double Take Mirror (Zero vibrations, easily to fold down for trail riding) ( ($50)
à Trailtech Digital Vapor Computer ($130)
It's unclear from your ad if it includes two sets of wheels.
You might consider separating what has been done to the bike and what "extras" are included, like the old AND the new version of whatever has been upgraded. One sentence listing extra parts might be sufficient.
Everything listed is included. 2 set of wheels, one dirt and one supermoto
What I meant was, "everything listed" didn't clearly indicate to me what was extra and what was a modification to the bike.
