engine wont turn over in gear?
my wr250x will only activate the starter if in neutral.. how can i disable this nanny aspect? thx
You might try disconnecting the neutral safety switch and grounding that wire .
I have a WR250R and it starts fine in gear. Sounds like you've got an issue with the clutch safety switch or wiring.
He's right. Shold start in gear with clutch lever pulled in. Also, won't start if kickstand is down. Pull in clutch& put up kickstand. If it won't start i gear this way clutch safety switch is bad.
