Suzuki When pulling over starter whines/spins
on the four wheeler I'm trying to get going for my neighbor when you pull it over the start spins. I pulled the start off and pulled it over and it didn't make any noises. The starter doesn't engage its self, Im not really sure how it works. Im also not sure what it is for a four wheeler. All i know is that it has the range selectors behind the gas cap and then the motor, tranny and rear diff are all together, with the dual square head lights under the front rack. It has aftermarket plastics also. Any ideas???
Edited by rayztruckz307
Souds like you're saying the starter itself spins, but it isn't spinning the motor. the gear on a starter is pushed out to engauge the drive gear, then retracts. what moves the that gear (on the starter) is called a bendix drive. on some starters the bendix can be replaced, maybe not on a bike or atv. probably need to replace the whole starter.
Edited by T-roy JK
