JR50 tire rubbing
I put a 2.75 rear tire on my sons JR50 and the chain is now rubbing. Whats the best way to handle this? Should I cut the tire, offset the wheel, or can I just let it rub? Its probably rubbing by about 1/8 of an inch. Thanks.
Just realized I got the wrong tire for the rear. Looks like the specs call for a 2.50. I guess I will just switch them out.
I'd just cut the tire, just make sure you remember to use the narrower tire when you replace it. Seeing as it's a mini, you'll forget to tell the guy you sell it to that the tire is too wide and you cut it.
I,would just get the right tire to start with LOL :)
