2000 125 plastics
Just the front fender. You could goto a Yamaha dealer and buy an Original 2012 yz 450 fender and drill the holes out a bit much easier and cheaper then trying to find a Restyled fender. It looks really good though!
you can use all the newer 125 plastics but you have to replace the seat, air box, sub frame, tank, shrouds, fenders, and number plates. It can be costly if you buy all new but it can be done
^^ Don't forget silencer mounts will need reworking. ^^
The simplest, most cost-effective path that many have taken is to do a 2006 & up front fender & number plate swap, then a 2002 & up fuel tank swap. Any thing more can be done, but as Jpeasey said it will be costly and requires some pretty serious fabrication work.
A TT search will uncover lots of info...
"2006-2008 Front Number Plate on 2000-2005 YZ250 How-to Post with Pics"
http://www.thumperta...post-with-pics/
"96-01 YZ to Modern 02+ Gas Tank Conversion"
http://www.thumperta..._1#entry944083
"96-01 to 02-up YZ Tank Conversion Information"
http://www.thumperta..._1#entry9352895
"2001 YZ250 makeover"
http://www.thumperta...62#entry6641062
Good luck!
Edited by CaptDan
