FCR-40MX Carb - Awesome Upgrade
I assumed that this might be the case.. 85 is actually moving pretty good for this bike. A slightly smaller rear sprocket may be in order. Or split the cases and get those second and fifth gear mods in..
Thanks dot.
Ok, after combing through all 21 pages of this thread I didn't see this question addressed:
What are people doing with the vacuum lines from this carb? Are they necessary or can I just remove them all together?
Vacuum lines or vent lines? there is a very important difference. my FCR "slant" doesn't have Vacuum lines and only two vent lines, I made a homemade filter that I run mine into because there was a considerable amount of dust getting into the top of my slide-which is bad...
The half dozen hoses are that hang off FCR is what I'm talking about. Didn't know if people were routing them up or down the frame, to the airbox or not, etc.
I can't remember if it was this thread or another one on ttalk. Four of the hoses are vent hoses and the one on the bottom of the float bowl is a over flow for the float bowl. I read to route two vent hoses one on each side of the carb up to the air box in case of a water crossing. The other two and float bowl overflow down between the front of the swing arm and back of the engine cases.
I think he was pointing out that they're technically vent hoses, not vacuum hoses.  Except for the one from the bottom of the fuel bowl that's an overflow drain.  They're there for a reason, so don't start blocking them off.
It's probably best practice to route the two top loop hoses to the air box, but I've done lots of deep and long water crossings without the engine stalling.
Normally all the vents lines are routed behind the back of the motor between the front of the swingarm.  That's how the OEMs do it too.  I've crossed rivers that completely covered the carb and never had any problems but rerouting them to the airbox makes some sense.  The only concern I can think of is routing it to the airbox would be the pressure swings might slightly affect the float operation and/or affect jetting.
Edited by D0T-C0M
Looking to make the switch also, found a good 07 250x CARB for sale, is there any benefit for a 250r carb over the 250x?
Has anyone tested this setup at high altitude (8000 to 12000ft).
What changes if any did you make to ride this setup at those kinds of altitudes?
WOW ramkas 8k-12k feet of elevation is very thin air.  For 10,000' elevation use,
NCVT or NCVS needle with the clip at the top most groove (1st from the top)
38 pilot jet
148 main jet
This should bring you very close.
Edited by D0T-C0M
Dot
Thanks. I am riding out of Taylor Park, CO in July. Will use that as my base line.
I picked up an FCR carb recently and im not sure if its a 40mm or 41. I measured the inside diameter on the inlet side on the carb and it measured 41mm. Does the throat taper down? Which way should I measure it? The seller said it came from a 2007 CRF250R which tells me its a 40mm. The main air jet is non adjustable if that matters.
Here are some pics.
Edited by craftsman13
The carb will work that's all that matters..I always measure the inside diameter of the inlet part of the carb as to size..you seem to be doing it correctly..What do you mean by the air jets non adjustable???..That carb should have a hole on the bottom front edge around the bowl area.,inside the hole is the fuel adjuster screw. It should be able to be turned with a screwdriver of the right size. It's easier to replace the stock one with an aftermarket adjuster which pokes out the hole allowing you to adjust it with your fingers..
Edited by Horri
y..What do you mean by the air jets non adjustable???....
the FCR-MX carbs has a fixed Air jet that needs to be swapped out for adjustment, the FCR "Slant" carbs have an adjustable Air jet.
ok..got it..Any idea where it goes..Is their a hole or something that's plugged up for the slightly nutty US state emmision standards.
Actually to be more specific there is a Slow Air Jet and a Main Air Jet, the slow air jet is adjustable on the FCR slant, I have read that the Fixed Slow Air Jet on a FCR-MX could be swapped out with a adjustable one.
I'm not actually sure what your asking "any idea where it goes?" unless you are asking what does it do? the Air jets are just part of the circuit for metering fuel for the pilot circuit  and main circuit, so there is no hole that would be plugged for emissions assuming that you would want as much adjust-ability to get the least emissions or power depending on your application.
If your asking "where is it on the carb" ? the red arrow points to the Slow air jet, the hole next to it is the Main Air jet.(you have to remove the bell in order to take them out)
Edited by jjast
Ok..Thanks for the detail..I was thinking they were like the fuel mixture screw that's on the front bottom of the normal FCR carbs..Bit of confusion but I think I grasp what you're saying.
Thanks for the replies. There is no main jet on the carb I have, i hope tuning wont be difficult. I also picked up a NCVT needle and am waiting for some jets and seals in the mail. I think for a starting point i am going to go with;
NCVT needle w/ clip on the 3rd groove from the bottom
158 main jet
42 slow jet
68 starter jet
100 slow air jet
70 leak jet
These are the jets that came in the carb except the main jet so we'll see how it works out. If anyone has any suggestions feel free to throw them out there.
