Actual weight difference....AF vs SF
I weighed my new 2005 aluminum frame and it came out to be 18.4lbs. After stripping the steel frame down, it weighed in at 24.2lbs for a weight savings of 5.8lbs. I had read a 4.4 lb difference so I gained weight savings over what was listed.
Not sure if anyone cared but I always wondered what the actual weight savings was.
Looks like a good project Josh. Wow 4.4 lbs. that is alot I would have guessed much less. Are you going to use the 03' or 05' pipe? When you get done be sure to give us a ride report. I'm wondering if you'll notice any difference in the vibration transffered to the rider?
